Want a free copy of PTC Mathcad Express? Download your copy today.
Author: Professor Valery Ochkov, Dr., National Research University "Moscow Power Engineering Institute"
Worksheets marked with use PTC Mathcad premium features, otherwise they are Express compatible. All worksheets created in PTC Mathcad Prime 2.0.
Worksheet name | Description |
Simple rankine thermal cycle | Calculates a thermal efficiency of an ideal Rankine Cycle with superheater. Input Data are pressure and temperatur of fresh steam and pressure in condenser. |
Entropy of Refrigerant R407c | Returns a specific entropy of Refrigerant R-407c as function of pressure and temperature. |
Enthalpy of water | Returns a specific enthalpy of water as function of pressure and temperature. |
Enthalpy of steam | Returns a specific enthalpy of steam as function of pressure and temperature. |
Returns a specific enthalpy of saturated steam as function of temperature. | |
Enthalpy of water on the saturated line | Returns a specific enthalpy of water on the saturated line as function of temperature. |
Entropy of water | Returns a specific entropy of water as function of pressure and temperature. |
Entropy of steam | Returns a specific entropy of steam as function of pressure and temperature. |
Entropy of saturated steam | Returns a specific entropy of saturated steam as function of temperature. |
Returns a specific entropy of water on the saturated line as function of temperature. | |
Temperature of water | Returns a temperature of water as function of pressure and specific enthalpy. |
Returns a temperature of saturated water as function of pressure. | |
Hydraulic network | Calculates the defined fluid flow of an NaCl aqueous solution depending on network parameters. |
