The simple exation with one variable needs numerical solving( with higher potential values compute time climbes a bit), enabled multithreading - not much of a cpu hog ~ 50%(on an i5 2500) - yet no result in prime 4.0
Punched the same quation into WolframAlpha, got an approximated result - due to limited compute time.
Searched though the help tool of the solve function, tried different parameters, still nothing.
Am I blind or missing something - please enlighten me.(used the thick equation symbol)
Thank you for wasting time on helping me 😉
Do you know about this tools
Mathcad is a numeric solver. It's symbolic engine is (and always has been) challenged. A numeric solve block (took longer to type):
A few options:
For Mathcad Express
Thanks for kudos!
But when we have 2 or more roots the Find and the root functions can return different answer (different numeric methods!)
PS root works in the free Prime Express - Find - blocked!
thanks to everyone for the quick responses! awsome community 🙂
