Solve Block Indexing
DJF
I'm looking at pipe flow in a series/parallel configuration.  Each pipe/flow/head is an index.  It works if I type in all the head loss equations individually, but I'd like to use a loop to automate it.  But, Mathcad doesn't seem to like it.
This works:
This doesn't work (no solution found):
Any way to get it to work?
4.0 attached.
24-Ruby V
(To:DJF)
Here are two ways to make it work. The first one uses vectorization and is the preferred one.
24-Ruby V
(To:DJF)
DJF
(To:Werner_E)
Ah, excellent work as always Werner.  I actually used the fun(Q) solution - as I need to add Moody factors and whatnot.
Thanks!
P.S. Don't you ever sleep?
24-Ruby V
(To:DJF)
Sleep is overrated 😉
Underrated.
-MFra-
(To:DJF)
WE let me joke a little ..... Since you are active 24h on 24h, Maybe you have microprocessors instead of neurons ..... in the brain of course .......
