converting mathcad 15 to mathcad prime
SOLVED
Hi, I'm a new user (but in fact a very old one) with mathcad prime 4. Since few month I'm my own boss. For the first time I have bought mathcad prime and install it, before it was TI guy who do that for me. But I have more than 6000 mathcad files  (from mathcad 8 to mathcad prime 3). I need to convert some of them but I need mathcad 15. I don't have mathcad 15 but someone explain to me that I have the right to install mathcad 15 and mathcad prime on the same computer... I can't use both mathcad in same time but only for converting.
Is it right ? where can I find mathcad 15?
Yves Rossignol
Re: converting mathcad 15 to mathcad prime
Yes, you can install MC15 parallel to Prime and it will be happy to use the same license file which Prime uses.
You can use both versions and you need MC15 to do the conversion from MC to Prime.
Find the english version of MC15 here
http://download.ptc.com/products/mathcad/trial/mc15/Mathcad15_EN.zip
https://www.ptc.com/en/products/mathcad/free-trial/thank-you
Your licence for prime should work for mathcad 15 too.
Download here:
http://support.ptc.com/products/mathcad/mathcad-15-0/free-trial?refid=cadventure
They can both run independently and it will  be available for conversion via prime under the Input/Output  tab.
Thanks you for all information. I will try this immediately
____________________________________ If you experience problems when attaching a Mathcad sheet file ( .mcd, .xmcd or .mcdx) to the message then zip it first. To get the .zip file, use Windows Explorer, select the sheet file, right-mouse click and select "Send to" then "Compressed (zipped) folder". This results in a .zip file containing the worksheet that you can attach
