matrix finite difference method
ptc-3682623
please try to find solusion of the problem in attachament. Please solve it for coefficients A B C f v = 1. I tried write the matrix but i've could not. Please help write correct matrix for my problem and then solve linear it. The matrix i the importantiest
1 ACCEPTED SOLUTION
ptc-3682623
(To:-MFra-)
Thanks for help.It was wery helpfull for me. But this is only 1 problem. We need it resume with the neuton-rapson method. I need only sample for it.
24 REPLIES 24
Couple things:
Mathcad considers that array and matrix indexes start at 0 by default.  You change this with the system variable ORIGIN.
The order you do things makes a difference.  I've put in a small example (3 by 3 instead of 440 by 440) to demonstrate:
I think for matrix K you intend to assemble as one large matrix, but you have made a nested matrix.
This shows how you assemble a larger matrix from four smaller ones.
Cheers
Terry
-MFra-
(To:ptc-3682623)
By chance, is the K11 matrix tridiagonal? that is:
ptc-3682623
(To:-MFra-)
-MFra-
(To:ptc-3682623)
Are you looking for Newton-Raphson in several variables algorithm? see attached.
ptc-3682623
(To:-MFra-)
Thanks for this informaction we will back to this nxt time.I ve done it but i am not sure if i did it correctly, would you like looking it in attachment?
-MFra-
(To:ptc-3682623)
I made some changes ....
ptc-3682623
(To:-MFra-)
Great job. Thanks. How we can write separately u and v? then see a graph in 2d for i and j parameters?
-MFra-
(To:ptc-3682623)
I do not know the various steps you did to get the matrix that I renamed MK, so I do not know how to proceed. u and v?
ptc-3682623
(To:-MFra-)
Look at the equation. we have u and v dimensions. Results is for both dimensions. We need to divide it on down matrix u and v. Then we need to show results on graphs.
-MFra-
(To:ptc-3682623)
I could hazard this solution ..... but it is completely heuristic ....
ptc-3682623
(To:-MFra-)
Hello, wow, great job. Would you compare solution in two case. For me is not the same. Is possibility draw  a graph u,v in 3d?
-MFra-
(To:ptc-3682623)
ptc-3682623
(To:-MFra-)
Hej. Thanks for solusions. Would you like preparining a situaction when we have orgin=1. This will be the best situaction. I going to prepare real seample and then I will show you it.
-MFra-
(To:ptc-3682623)
ptc-3682623
(To:-MFra-)
Hi, I am from Poland, I've been writing PhD and I have some problems with the finite.... I need to take your solisions and think how it write with real coefficients. I going to write it and we will think about it.ok?
-MFra-
(To:ptc-3682623)
Ok!
ptc-3682623
(To:-MFra-)
Hi. I could not have solved my problem. In attachment you will find a sample of shield. I discretizationed it and for it we have model of finite difference method the same like last time. for point 3 - u,v=0 for point 28 - u,v=0. For point 5,10,15,20,25 - right site of equation is 10. Please help.
-MFra-
(To:ptc-3682623)
Please be clearer. You should consider the fact that I am not aware of the physical system related to the differential equations that you have published, so I do not know how to help you.
ptc-3682623
(To:-MFra-)
ok. i will write some. I need only help in mathcad I can write what we need to do in Word.
ptc-3682623
(To:-MFra-)
I ve done some. I do not know why i have 74 x74=K we need 72x72 and order are the same like in sample. positions 36 of v are ok. this means 36 u and 36 v from beginning 1,i and i,1
LucMeekes
(To:ptc-3682623)
You've set N:=72, and you let j run from Origin to N+Origin (that's up to N+Origin=72+1=73).
Then you index MK up to j+1. That makes 73+1 =74 maximum.
-MFra-
(To:ptc-3682623)
ptc-3682623
(To:-MFra-)
Hi. I ve done some but I need to do stresses and I do not know how to take into account boundary conditions. Solution is without it.
