Creo Parametric 2.0 integration with Mathcad Prime 3.0
Sapphire I
Creo Parametric 2.0 integration with Mathcad Prime 3.0.
(view in My Videos)
3 REPLIES 3
Re: Creo Parametric 2.0 integration with Mathcad Prime 3.0
Vladimir,
I am curious on how the use of PDMLink with with is working. We tried to do this with Prime 2.0 and the WGM connection seemed fairly flaky at best. Has there been any improvements along these lines?
Also, have you added the ability to make degrees the default instead of radians? This seems odd that this isn't available since Creo doesn't work with radians without a conversion and that Mathcad is supposed to be an engineering calculation tool and the only people that I know that really use radians are mathematicians. Please add this to the list if its not already available.
Best regards,
Andy
I can't able to find Video
Highlighted
Good tutorial.
I m wondering how to tranfert String parameters from creo to Mathcad and vice versa.
Is there a way to do that ?
Thibault
