Hi all,
I have some problems with an equation that tried to describe the displacement in x direction of a piston moved by a constant pressure. On the opposite side, to counter the movement, I have:
I'm not able to resolve the equation.
I've removed the units of measure in the eventuality they could interfere in the process.
I use MC 15.
Regards
Mathcad wants the (at least highest order) derivative on the LHS of the equation.
