3D graphs
fpettazzi
3D graphs
I have 2D matrix (NxM) created with indices which I like to plot in 3D. I wish to change the axes to display not the indices but rather the actual vector that have generated them (with units).
Please see the attachment.
How can I do that?
RichardJ
(To:fpettazzi)
6 REPLIES 6
-MFra-
(To:fpettazzi)
Hi Federico,
Click twice quickly on the chart, so as to show the control panel as shown below. With it you can make any changes you want.
fpettazzi
(To:-MFra-)
Hello F.M.
Thanks for the answer....I was looking more to what has been posted below from Richard & Werner.
Best
F
RichardJ
(To:fpettazzi)
fpettazzi
(To:RichardJ)
Thanks! This is what I was looking for.
Cheers
Federico
Here is a solution which just uses a function P(R,I) and CreateMesh, but the drawback is, that is has to be used unit-less and to show the results in other than the base units, you have to modify the function, which may be misleading. So you might prefer Richards solution.
fpettazzi
(To:Werner_E)
Dear Werner,
Thanks a lot. I indeed find the solution of Richard more practical, but I am not familiar with CreateMesh and I will use your file to get to know this function.
best
Federico
