About StudyWorks version
ElsbrIII-disabl
Hello. The version of StudyWorks I am using will open most ( but not all) files with extension MCD but will not open files with extension SWK. Why not?
Thank you,
ElsbrIII
>SWK. Why not?
>Thank you,
> ElsbrIII
Can you post an example file?
TTFN,
Eden
Thanks; I will now attempt to post an Example file.
ElsbrIII
YOu should be able to see the version by looking in help/about. Generally such products will open files from earlier versions, but not later versions.
What format does your version store in? It should be .swk. Does it open the files that it saves? If not, what error message does it produce?
__________________
� � � � Tom Gutman
