Acquire index number
fahmed-2
I want to assign a number in "d" from "b" in the following way. Firstly, I will input any number in "c". Secondly, I want to acquire the index number from "a" such that the value of "a" matches with the value of "c". Thirdly, Then with that, I will assign a value from "b" to "d". I can do the first and third part but cannot do the second part. It will really be helpful if you please help me out.
Faisal
1 ACCEPTED SOLUTION
Something like this?
4 REPLIES 4
fahmed-2
(To:Werner_E)
why did you give an index "0" around the brackets ("c,a").
Because "Match" and also "Lookup" return a vector of values as there could be multiple values found. The vector index 0 (or you could use ORIGIN) just takes the first one.
In your example there is only one value found but the result still would be a vector, a 1x1 vector/array.
fahmed-2
(To:Werner_E)
Thank you very much
