please attached sheet. i would like to be to add the spacing dimensions and create running dimensions. Thanks!
This will not work correctly if there are intermediate zeros between non-zero values, but I gues that can't happen for rebar spacings!
Thank you Richard!
i will not have intermediate zeros between nonzero values. Thank you!
