Advanced Problem Solving: Final Problem — The Spring Constant
TudorMarin
In this final section, you work through several problems that all deal with the same physical system: a mass hanging from a spring. The background section (below) will review some of the physics involved with this system.
In working through these problems, you will use most of Mathcad's features that you have learned about in this Problem Solving Tutorial. We hope that you will also use the problem-solving techniques that we have emphasized as well. Good luck!
0 REPLIES 0
