Aligning Regions Vertically in Prime
AndrewPower
1-Newbie
I am trying Prrime for the first time today.
How do you align regions vertically? I know how to do it in M15, but I can not figure out how to do it in Prime. I also can not find in the help guide.
Andrew
2 REPLIES 2
Acording to the migration user's guide (under the getting started tab), region alignment feature is not included in Prime1.0. The regions snap to the grid so you can use that instead.
You'll find the help guide under the getting started tab also.
I hope this helps.
Norm
MikeArmstrong
(To:AndrewPower)
The above post is correct.
You can also change the grid size which makes it easier to align.
Mike
