Area Under Curve-Integration
SOLVED
Jacob_S
In the attached plot i have power dissipation on y -axis and  time  on x-axis. My objective to integrate the waveform(on y axis- Area under curve) and then divide by time(x-axis: Time taken for covered area ) to get the average power dissipation. I am trying get an integral plot similar to the one  we get in the math waveform (integral function) in oscilloscope. I am attaching a video link regarding the same
https://youtu.be/Dh0xYu8YvaE
I am also enclosing the .csv file
In this tutorial Dave demonstrates the seldom used and often little understood mathematical integration function available on your modern digital oscilloscop...
LucMeekes
23-Emerald I
(To:Jacob_S)
In other words:
You can only 'integrate' (use the integration operator) when you have a description of the function that you want to integrate. You do not have a function, but a set of data points. The best you can do is sum the numbers over your range of interest, and divide by the time difference over that range.
See if the attached helps.
-MFra-
(To:Jacob_S)
Jacob_S
(To:-MFra-)
Thank you
LucMeekes
23-Emerald I
(To:Jacob_S)
In other words:
Jacob_S
(To:LucMeekes)
Thank you very much for the detailed answer
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
