Assigning a default or on error value if a find() solve block finds no solution
SOLVED
Highlighted
Newbie
Related topic - http://communities.ptc.com/thread/51436?tstart=0
Hi all,
How can I assign a default or on error value if solve block gives no solution?
See attachment.
Thanks in advance!
1 ACCEPTED SOLUTION
Re: Assigning a default or on error value if a find() solve block finds no solution
Thats easy to do - you just have to turn the solve block into a function.
You may even plot 2Dgraphs like Fx over M or 3Dgraphs like Fx over M and Q if that would have any meaning.
See attachment.
2 REPLIES 2
See attachment.
Very tricky but works like a charm. I think it will take me some time to master MathCAD.
Thanks a lot, Werner.
-Alan
