Base Conversion
Newbie
Base Conversion
Knowledgable Colabs:
I have a stupid little calculator, that when asked will convert a number to base 2, 8, 16 etc. within its ability to write letters for 'digits' greater than 9.
I have Stuarts file "Boolean operators" posted somewhere on thir forum, but afaik, it uses vectors and base 10 numbers for higher bases, rather than the alphabet letters.
Does not MCad have functions for base conversion? Would someone please point me to those nice built in functions. Can we not do standard arithmetic in base 2 or 8 or 16?
I already know about inputing numbers in those bases. But i want to input in base 10 and get out base 2 or 16 specifically. Fortunately, the days of using a DataGeneral computer are passed and octal is unusual.
narlin
6 REPLIES 6
Base Conversion
Not as far as I'm aware, Narlin, but ...
You can use the in-built Mathcad result display option:
Menu: Format/Result (or double click on a result)
on the resulting(!) dialog, select Radix under the tab Display Options - you can even have octal.
There's another variant at http://collab.mathsoft.com/read?68541,12
The file Boolean Operators.mcd does letter conversion as well, but as the string is returned in quotes that it still looks weird, unless you want to employ a tailored text box.
Stuart
Base Conversion
Mathcad can handle binary, decimal, otcal, and hexidecimal. To dispaly a result, select format/result/display options/radix.
To input a result use b for binary (11b = 3)
o for octal, and h for hexidecimal
Fred Kohlhepp
fkohlhepp@sikorsky.com
Base Conversion
Mathcad until version 11 (included) can handle any conversion. The secret is Maple...
Re: Base Conversion
Although Mathcad can do arithmetic with numbers in a few bases, there is apparently no facility to specify a variable as binary or hexadecimal, for example.
TIA
- David
Re: Base Conversion
Back more than a decade ago, when this thread was started, sure there was. In Mathcad 15 you can specify binary, haexadecimal or octal as an input or result:
Then PTC took over, and gave us Mathcad Prime Smiley Sad
Re: Base Conversion
Well,..... Had they actually given it, there would be less of a problem.
But they're trying to sell it instead of Mathcad.
