Batch Mode Processing?
Highlighted
Newbie
Is there a way to run Mathcad in some kind of "batch" mode.
Our Mathcad analysis files read data from disk and write results to disk. We want to be able to update the results by running these with a minimum of user interaction.
Is there a way to tell Mathcad to startup with a certain file, do a "calculate worksheet", then close the file or shut down?
Frank
Highlighted
It appears that there is automation support, which means that MathCad can be run from VBA.
I can't help more because the help for these objects is not coming up on my installation.
