ldante
11-Garnet
CWD
Hi
What is CWD setting in mathcad ?
Hi, In the help. https://support.ptc.com/help/mathcad/en/index.html#page/PTC_Mathcad_Help%2Fbuilt-in_constants_and_variables.html Name Default Value Use CWD Current working directory Use this system variable as an argument to file handling functions. (in the form of a string variable) To see what it is set too type CWD:= into Prime or Mathcad 15. Cheers Terry
ldante
11-Garnet
(To:ldante)
I have an error in my spreadsheet  " PTC Math CAD is using the setting of the current worksheet, not the CWD from the  C: /////. How to fix this?
Thank you.  problem solved ..
is there a way to keep this persistent, or do we have to set it every time we open mathcad Prime  ?
