Calculations-check
massai
Calculations-check
Does anyone know if it's possible to let mathcad show the digits inside an equation so quality-control of the calculations is more effective.
For eksample:
a:= 2 b:= 5
c:= a*b
c=2*5 [how can i let mathcad show this automatically??]
c=10
I know about the explicit-funtion, but it is very unhandy when you're working with long equations. I think there should be an easy way to show the inside of a formula. Perhaps I just don't know about it... 🙂
EXPLICIT is the feature for substituting in previously-defined variable values.
Preston
Massai,
I suggest you right-click on the equation and tick "hide keywords". This collapses away the bit you don't need.
I further suggest that you type "explicit,a,b,c=" to show the equals sign and the numerical result on the same line.
Imran Nawaz
Just solve in separate steps: one to show intermediate result and another to show the fully solved version.
Hopefully, massai is still interested in an answer after more than 9 years of waiting!
You're about to resurrect a dead thread 🙂
BTW, the use of the "solve" command in your answer is misleading. You should rather use an assignement c:=a*b than using an equation c=a*b which is then solved for c.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
