Can someone help me?
SOLVED
Highlighted
Newbie
Hi guys,
I keep getting an error on a formula, but the formula is just from one of my textbooks, so there isn't much I can change.
I am wondering why mathcad keep giving me this error.
See attachment
Tags (1)
1 ACCEPTED SOLUTION
Re: Can someone help me?
The units are inconsistent in the equation.  It's physically impossible to add Length^-0.5, Length^-1, and Length^-2.
Your equation is likely empirical where L.tot is expected to be a certain unit.  Assuming that L.tot is expected to be in meters, and a.0 is supposed to be unitless, you can modify the equation like this:
which can also be re-written as:
If a.0 is expected to have units, just multiply the whole equation by those units.
1 REPLY 1
