Cannot calculate a definite integral of a matrix
SOLVED
rsulwinski
I encountered another problem in Mathcad 15. I want to calculate a definite integral of a matrix (to be more precise, Mathcad should automatically calculate a definite integral of each matrix entry). I am getting an error "this calculation does not converge to a solution". However, when I manually define the definite integral of each matrix entry, Mathcad 15 obtains the solution without a problem. In the attached example the matrix size is 2x2, however my calculations will deal with few dozens of matrices with sizes varying from 6x6 to 15x15 (user defined size). Obviously I want to avoid typing 36 or even 225 integrals manually. Does anyone know a solution to this problem or yet another Mathcad bug? Thank you in advance for your help.
Best regards
Rafal
Thank you for your reply. This method works, but is very slow for more complex functions and larger matrices. I found that by using the "float" command the calculation speed is increased a lot.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
