Cell counting
ptc-5743339
1-Newbie
Cell counting
Hi!
I'm trying to develop a program wich can count the number of cells contained in the following image:
For such a task, I need to find the perfect values for the canny function in order to performing a succesfull "reg_grow" wich "paints" each of the cells as a white circle and then the task of counting those white circle is easy.
So, here is my attemp: Some of the cells are succesfully colored, but other ones still being without coloring.
I really hope that this would be a matter of the values in the canny and reg_grow functions rather than a problem with the image itself.
Thank you.
3 REPLIES 3
I hought the goal was people counting?
Did you look at the last post here; http://communities.ptc.com/message/237229#237229 ?
Yes, I've seen that post and was extremelly helpfull.
That program was that helpfull that my company wants me to use it in a lot of different examples, different from people counting, such as this...
I can't think of any automatic procedure giving you what you want for any pic. But then I'm not that well versed with image processing.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
