I want to include a check box to indicate if the value of a variable is greater than the value of another variable. I was wondering this is possible and how to do it.
Yes, that is easy to do.
You may also be interested in this: http://www.imakenews.com/ptcexpress/e_article001338547.cfm?x=bf70tQM,b3jsqcsB,w
You can use a picture #1 show when a>b a picture #2 show otherwise.
One example on Mathcad Server:
http://twt.mpei.ac.ru/MAS/Worksheets/IF_in_WorkSheet.mcd
The picture #1 is a full check box and the picture #2 an empty check box!
