>>Yes, READBIN is better than READPRN - I've added it to my original worksheet.<<
Depends a bit on what you are trying to accomplish. Using READPRN checks not only for existance but also for a certain level of validity. For the original purpose, checking to see whether a result file had already been generated, that seems appropriate.
For the READBIN I would suggest adding some parameters to only read one byte. No need to read the entirety of a large file, at eight bytes per character, to determine if it exists. For large files the time and space considerations could be significant.
� � � � Tom Gutman
