Hi im writing my master thesis, and im almost done, as a last step i want my values to be exported to excel, and i know how to do this BUT.
My problem is that i want to repeat the calculation with different parametars, and after that upon the users will, the values will be exported.
In my case, i have done a automatic export of the values upon every recalculation and i want a button of some type that does this when clicked
The task: One button click to export all the matrixes.
Ofc the script will be later integrated into my orginal script and Matrix A to E will be different and present different load-cases and stages.
Also if you cant help me, you might want to take a look into the strings I have created that first calculates how many rows in excel that have been used and print the data after that row, so you can collect samples for different input-data, into same file without having to change the write function manually.
Im also aware that i could do a for loop to make the script shorter, i will do later. Im asking about the button
I have checked scripts recommended for using buttons to export data to txt. but they didnt work in mathcad 15.
If you can, i want the button to be double clicked to activate it.
See here: Extra Components and Controls
There is a button that can be used to control the execution of code. This can be anything, including file writes (writing files on demand was in fact the reason I wrote it!).
Never mind, I made this solution, and it works pretty good
For the one who is intrested take a look at it.
I have looked at the file you sent before making this thread, sadly your example didnt work on my computer but i know it worked for others. Thats why I posted the question. It might be that the student version im using is limited or something like that. Have no clue. But i made an alternative solution, less pretty than yours but it will do thanks for the post
The student version has the same functionallity as the full version. Can you post the worksheet where it doesn't work?
I used the same mathcad file you linked tried to make it work from there, and also to cut just the script and try it on a new worksheet. I know others who made it work. I have worked around this with a normal function instead of button. Thanks for your efforts
