Compare multiple vectors with a single value?
dsochor
The attached worksheet attempts to find the maximum of each line of two vectors and a single value. What needs to be done to make this work?
It's modeled after the answer from the following prior discussion: Minimize between vector and a single value
1 ACCEPTED SOLUTION
Here is the file with Richards suggestion of how to use your function along with an alternative approach using a function which returns simple the maximum of 3 scalars and then is called vectorized with the vectors as arguments. This function could also be used in the way you tried using the range i.
Regards
Werner
4 REPLIES 4
RichardJ
(To:dsochor)
Your for loop starts at 0 and you have ORIGIN set to 1.
dsochor
(To:RichardJ)
Thank you Richard; that is a good catch. No dice though.
RichardJ
(To:dsochor)
You should be passing vectors to the function. If you pass, for example, l.dh[i,2, you are passing a scalar value
Regards
Werner
