Concatened matrix
XDN
Concatened matrix
Hi
I want make a program for concatened matrix
for example i want to obtain it:
How make a program for this ?
In this example , matrix 3x3
in final application matrix nx3
24-Ruby V
(To:XDN)
So you would have to explain in more detail how the matrix M is supposed to be built.
I your example (n=4) M has 23 rows !?
The values +8.33 and +25 are never used in M.
I would have expected rather either 3*n (=12) or n^3 (=64) lines in M
What about the zeros in the three matrices? Is there always just one column in each of the three matrices relevant?
Could it be that you are looking for something like this:
14 REPLIES 14
Use a combination of the stack, augment and submatrix functions.
Alan
XDN
(To:AlanStevens)
Please you can make me an example ?
I don't see how to make it ?
XDN
(To:XDN)
I try it:Capture-4.JPG
24-Ruby V
(To:XDN)
This little program should do the job:
Worksheet in Prime5 format attached
XDN
(To:Werner_E)
Great !!
i try to understand it Smiley Happy
XDN
(To:Werner_E)
It's very well for me
but i don't understand perfectly your algorythm
i try modify it but i no have a sucess
I my final application
First Step
your program is right
Second step
I need to make a matrix  M1 with B mark
for example:
0     -5     0
-20  -5     0
0     -5     0
5     -5     0
0     -5     -1
0     -5     0
0     -5    1
And third make a matrix M2 with C mark
for example
0     0     -1
-20  0     -1
0     0     -1
5     0    -1
0     -5     -1
0     2   -1
0     7    -1
LucMeekes
(To:XDN)
See if this does what you need for M1 and M2, making use of Werners function.
XDN
(To:LucMeekes)
Great Luke
i make a new parameter
A'
B'
to match with werner's algorythm
You are great's people
Thank's for all
24-Ruby V
(To:XDN)
Guess here is a solution using just one function. The argument order of the three matrices is vital, though.
Don't forget to close the thread when there is no further question.
Worksheet in P5 format attached.
XDN
(To:Werner_E)
since yesterday my problem was update, but's it's very similar
I have some difficult with program
I don't understand perfectly your algorythm
I try to modify it for my new application, but i don't have a sucess
Now, i have a algorythm wich generated 3 matrix.
This matrix are the coordinates points in 3D space axis by axis
X matrix
Y matrix
Z matrix
I need a generated M matrix wich include all 3D coordinates of axis point from X,Y,Z matrix.
And finally i verify it with 3D graphic
for example (here matrix have only 4 rows, in finally we have n rows)3D_pnt.JPG
24-Ruby V
(To:XDN)
Looks to me like something completely different than what you had asked for before.
XDN
(To:Werner_E)
Yes ! because my first approach are erroneous
i'm sad
24-Ruby V
(To:XDN)
XDN
(To:Werner_E)
Sorry for the time to make answer...
Yes ! Zeros are not necessary in matrix
Thanks it's great !
it is that's y want !
Thanks for all ! i learn some things with your example
very thanks
