Congruences, Divisibility Test
SOLVED
klian
1-Newbie
Use an appropriate function using Mathcad to find the remainder when
12345678981129 is divided by 5518.
Can anybody help in this?
Beginner in Mathcad...
1 ACCEPTED SOLUTION
7 REPLIES 7
RichardJ
(To:klian)
Look up the "floor" function.
AlanStevens
(To:klian)
Or the "mod" function.
Alan
RichardJ
(To:StuartBruff)
And here endeth the beginners lesson in Mathcad
Interesting observation about the built-in mod function though
Thxs, Sir...
As for trunc and floor, I don't really understand. It don't seems to give the right answer to the question by using trunc and floor.
I will practice on it and figure it out...
Regards
Sir,
It seems like = sign is not showing the right answer for some other questions.... Symbolic processing is more appropriate.
Thxs again.
Regards
Sir,
Yes.  For large integers (more 15 digits), the numeric processor will have limitations on how many digits it can store and, consequently, on how accurate the divisions will be, even with smaller integers as the divisions may not have sufficient (binary) digits to be exact.  The symbolic processor should be able to handle reasonably large numbers ...
Stuart
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
