Hello
I've just downloaded the free trial Mathcad Express Prime 3.1 in order to check a script I recieved, but apparently the conversion function is only available in the full version.
Is it possible to do the conversion elsewhere or just into pdf so I can see the script?
The script is attached below.
I would really appreciate any help I could get!
Yours sincerely
Svante W Monie
You need Mathcad 15 installed to use the conversion function. (That's why version 15 is free when you purchase Prime.
There is still (I think) a free 30 day evaluation of 15 available.
PDF attached.
PDF attached.
Thank you very much! It would have been nice to run it, but as long as I can view the script things are splendid.
Any idea how much the Prime version costs?
Best regards
Svante
Mathcad 15 30-day free trial can be found here:
http://www.ptc.com/products/mathcad/mathcad-15-0/free-trial.htm
Thank You for Your Interest in PTC Mathcad 15 | PTC
PTC web store for buying Mathcad Prime:
http://store.ptc.com/store/ptc/DisplayHomePage/
http://store.ptc.com/store/ptc/DisplayCategoryProductListPage/categoryID.5321800
