Convert Mathcad 15 to Prime 2 break function
Durbal.Andrew.H
8-Gravel
Am converting some existing Mathcad 15 files to Mathcad Prime 2.0 but have come across an issue where by the "break" programming syntax does not work in the same way and I can not figure out a way to replicate the level of functionality required.
Any ideas from the community? Image and example file attached.
Thanks in advance.
It's a poor program structure even inMC15, where it works! Better to program this as:
Alan
Alan
The break is normally used to break out of for/while loops.
I fully agree with Alan's response. An alternative might be as shown in the attached.
