Hello.
The question I have is whether you can convert a string to var, in other words, remove the quotes (") of the variable. Example:
"Text" -----> Text
Thanks in advance
In Mathcad 15, yes.
Thank you very much Richard, I thought that there is a way to do this without using script, but anyway the file was useful to me.
This is the only way to do it that I know of.
