Convert to Prime 6
aryehsc
3-Visitor
Convert to Prime 6
can anyone help me and send me a converted file for prime 6
since I have only prime 6 installed and can't convert.
tried to install version 15 and it won't take my prime 6 licence file, so i uninstalled it.
Sanath
(To:aryehsc)
@aryehsc, Download and install Mathcad 15.0 M050 version. If you have Mathcad Prime 6.0 license, then Mathcad 15.0 will definitely work with the same license.
Please see the attached converted file for you. Compatible with Prime 6.0
aryehsc
3-Visitor
(To:Sanath)
I tried to install Mathcad 15, it didn't acknowledge my prime license
And you are sure that you don't confuse "product number" and "license"?
If you got a product number to install Prime, then the MC15 install process would not accept it.
Rather when you install MC15 you should chose the option "I already have a license" (not sure about the exact wording) and then point the installer to the license file (usually "license.dat", not sure about the exact path) which was created when you installed Prime.
