Converting Lowercase text to Upper case..
ptc-2161629
Newbie
Hi, I am wondering if there is a feature in MathCAD that would allow a user to change the lowercase text to higher case text. regards
11 REPLIES 11
RE: Converting Lowercase text to Upper case..
Do you mean text in a text region, or do you mean a string held in a variable? Richard
For example if there is a text "the shear capacity of beam" needs to be converted to "THE SHEAR CAPACITY OF BEAM" ie, converting text from lowercase to uppercase.. thanks
That doesn't answer my question. If the text is a sting in a variable then it would be possible to write a function to convert it to upper case: a:"the shear capacity of beam" b:ToUpper(a) b="THE SHEAR CAPACITY OF BEAM" There is no such built-in function, but it could be written without too much trouble. If you posted the question to the main forum ( http://collab.mathsoft.com/~mathcad2000 ) you might even find that someone has already done so. If the text is part of a text region, then the answer is "no". At least, not in any simple way. In principle you could write a function based on a scripted component that would modify the XML in the Mathcad file, but it would be a lot of work. Richard
Hi, Many thanks for your prompt response. I was actually looking for a feature similar to what you have in MS Word. In Word, you can select a string and then click on a button on the menu to change the string to uppercase. coming to the solution that you have given, I have tried "ToUpper(a) function as suggested by you; but the function doesn't seem to be available in MathCAD 14.0 that I am using. regards
Hi Richard, Many many thanks for your feedback.. regards surya
Re: RE: Converting Lowercase text to Upper case..
Thanks Richard!!!
Re: Converting Lowercase text to Upper case..
I was looking for the same function but ended up creating my own function.  Hopefully the functions I created will help someone in the future.
The example attached is in Mathcad Prime 6.
Here is a variant which also deals with a few special characters used in my language.
"isIn()" normally would be a standalone function along with others placed in a collapsed region at the top of the sheet. I made it a local function to the conversion functions to make them self-contained.
P6 sheet attached
Tags (1)
Here's the same functionality that also works in Prime Express (4 and up).
