Converting Problem PRIME 2.0
SOLVED
Newbie
well the first problem was the registered Mathcad 14, but after deleting that and reworkink regdotnet, the problem remains.
The converter hangs after hitting "include references"...
any ideas?
thanks
Tags (2)
Re: Converting Problem PRIME 2.0
running mcregister solved the problem...
hmm but the OLE - components (in- and output) do not work anymore both in Mathcad 15 and Prime...
What service release of Mathcad 15 do you use for the conversion?
