Copying an Excel component from and to MathCAD gives an error
Edd
1-Newbie
1-Newbie
I have created an Excel component (Insert -> Component -> Microsoft Excel -> Create from file) and it's working perfectly. However I have to use this component many times in my MathCAD sheet, so I'm trying to copy it. When I right click the component and choose copy, I get the following error message, in a window titled "Microsoft Excel":
" cannot be accessed. The file may be read-only, or you may be trying to access a read-only location. Or, the server the document is stored on may not be responding.
Does anyone know how to avoid this ? I could create the component again ofcourse, but I need it so many times that this would be too much work.
Best regards
Edd.
1 ACCEPTED SOLUTION
MikeArmstrong
(To:Edd)
Best regards
Edd.
Edd,
Post a worksheet of the problem.
Mike
4 REPLIES 4
MikeArmstrong
(To:Edd)
Best regards
Edd.
Edd,
Mike
jeanGiraud
1-Newbie
(To:Edd)
Isn't true Mona just announced recently Mathcad 15 compatible with Excel 2010 ?
jmG
Edd
1-Newbie
1-Newbie
(To:Edd)
Hello Mike and Jean,
Thanks for your time, but I cannot post the MathCAD file here since it is company confidential. I was hoping there would be a generic solution to my problem. I have been trying to reproduce the problem with a new sheet, but the copying (usually) works fine. So there is probably something wrong with my specific sheet.
I'll contact the PTC helpdesk on this.
Best regards
Edd.
MikeArmstrong
(To:Edd)
Edd,
You could try and reproduce the problem with generic data; therefore there would be no issue with your company confidentiality.
There might be a simple solution to your problem, but without a worksheet its hard to see what the problem is.
Mike
