Hi PTC Mathcad Community,
I have this Mathcad Prime 5.0 file in which many regions are apparantly corrupted. I think this is due to having math regions inside text regions. This is the first 3-4 pages, and the last few pages are ok.
Is it possible to fix the file?
How did you get this file. In particular: was it created by conversion from a Mathcad (15 or before) file?
I created the file myself. I am a user of Mathcad Prime 5.0
Well, apparently something went wrong in Prime. Consider yourself lucky that the file still opens at all. I've seen corruptions that resulted in Prime not being to open the file. In some cases the worksheet can then still be recovered, but (links to) any embedded text is lost.
I hope you have a backup (or print-out) from which you can reconstruct the missing part(s) in your file. I see at this moment no option to recover the info from the file.
It may very well be that you created this file yourself, in Prime 5. But then WHY oh why does it contain this annotation for the corrupted part:
I've checked and found no traces of information that would allow restoration or recuperation of the corrupted region in the .MCDX file.
Incidentally: The file was created by "Barakat Bokharaie".
