Creating a program function ? (III)
lvl107
20-Turquoise
   Hello Evevyone,
   The Question : Create a program function MarkMaxElement(   )  ?
       Thanks in advance for your time and help.
             Best Regards.
H, A, P and Y are the letters we see twice in the whole matrix and no letter appears more than two times. So these four letters qualify for being the max elements in the whole matrix (ex aequo). See also here -> Creating a program function ? (II)
But I like Freds contribution and would second it - WHY?
@Loi Le
If you have a special application where a routine like this is needed, you may tell us which.
If you just want to learn programming in Mathcad, it would be better to give it a try yourself and come back here with your attempt if you experience any problems.
Fred_Kohlhepp
23-Emerald I
(To:lvl107)
Why?
LucMeekes
(To:lvl107)
Unclear.
Assuming that the (xxx) elements are 'marked', what is the criterion for "H", "A" and "P"s to marked (in the first row), and why aren't "S"and "D" not marked in the last row?
@Loi Le
