Creating units
Creating units
How do I create new units such as specific volume for some thermodynamics work?
TIA
D
Creating units
>TIA
>D
I assume that you're referring to the inverse of the density, m3/kg
Define it as you would any other term:
sp_vol:m3/kg
Then, in your result, tab to the placeholder and enter the unit you defined. Mathcad will then convert the numerical result to conform to the units used.
TTFN,
Eden
Creating units
Units in thermodynamics works and many usefull:
www.wsp.ru
The Program WaterSteamPro
Valery Ochkov
http://twt.mpei.ac.ru/ochkov
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
