Creation a plot with error bars (Y and X axis)
SOLVED
Level 1
Hello, Dear Mathcad users!
It's my first lessons on mathcad prime 2.0, and I'am trying to create a plot with error bars (Y and X axis).
I managed with Y-axis, but I cannot make the same on X-axis.
Could somebody help me how to do it?
The file I've created attached.
Andrey KIselev
Student of Moscow State University.
Re: Creation a plot with error bars (Y and X axis)
This was possible in Mathcad 15 (see the attached worksheet), but it no longer works in Prime due to a serious limitation in the graphing. Until they fix this, I can't think of any realistic way to do it.
12 REPLIES 12
Thank you, Mr. Jackson.
It's a pity that the latest version of Mathcad can't manage with some old tasks.
But, nevertheless, you was wery helpfull.
Best reguards, Andrey.
Hi Richard/All,
Does anyone know if this has been fixed in Mathcad Prime 2.0 yet?
I am planning to have my students use Mathcad to do their physics lab write-ups and error bars (both x and y) would be really useful!
Also does anyone know how to do the maximum and minimum slopes of the lines of best fit that pass through all the error bar lines (for example, see attached picture)?
ps - anyone got any ideas on how to represent/deal with uncertainties in measured values that you put into a data table using the "insert table" feature?
The x and y error bars can actually be made to work in Prime. Put the cursor in Re(xBars) on the graph axis and change the plot type to waterfall trace. Then do the same for Re(yBars).
Here are worksheets that show how to fit a line to data with errors in both x and y (there is no built-in Mathcad function to do it) and how to calculate the errors in the fitted parameters (this worksheet was taken from the Data Analysis Extension Pack in MC15). Unfortunately, the error calculation assumes errors in y only, and I don't have a worksheet that shows how to do these calculations when there are errors in both x and y. The Mathcad Prime files are for Prime 3.0 (sorry, I have no way to convert to Prime 2.0 format). The Data Analysis Extension Pack didn't convert perfectly, but it could be fixed.
Hi Richard,
Thanks so much for responding!
Just a few follow-up questions though:
-what do you mean by "Re(xBars)" and "Re(yBars)"?
-the academic version I get as part of the PTC Schools programe is Prime 2.0. Is it possible for you to post .XPS file exports or screenshots so I can see what method you used?
-finally, any idea how to put the +/- uncertainty into a table of values created by using the "insert table" feature? Because the format seems to be fixed as <variable1> <units1> , <variable2> <units2> etc, so you can put x (s) and y (m) but not x (+/- 0.1s) and y (+/- 0.01m) for example. I guess worst case you could add separate columns for the upper and lower uncertainty bounds, right?
Cheers,
Benson
That's actually very obvious if you look in the worksheets.
Your Prime 2.0 license file will work for Mathcad 15, which you can get here: http://www.ptc.com/product/mathcad/free-trial/thank-you. If you have Mathcad 15 installed you will also have a converter installed that will convert the Mathcad 15 files to Prime 2.0 files (although you will have to do a couple of fixes after the conversion).
That's the only way I can think of.
Hi Richard,
Thanks again for the clarification.
I've now upgraded to Mathcad Prime 3.0 and opened the files that you attached, but there does seem to be quite a few problems with the formatting, and I can't find a reference to Re(xBars) or Re(yBars) anywhere. Moreover, the statistical methods used in those sheets are far too complicated for what we need to do in IB DP Physics.
Basically, all I need is a simple example, showing how data with uncertainties could be put into a table and then plotted with error bars and max and min slope lines of best fit. In other words, something just like the below example, but augmented to include uncertainty data, error bars in x and y and max and min slope lines of best fit (and with slightly less scatter in the data, of course!).
Do you (or does anybody out there) have something like that you could share?
Thanks!
