Creo toolkits startup error
Newbie
Guys, I'm trying to make a linkage between Ansys Workbench and Creo Parametric 3.0. But this error keep on popping out. What should I do? URGENT!!
Re: Creo toolkits startup error
open .dat file mentioned in error message in Notepad and check if it contains valid paths to files/directories. Correct paths if it is necessary.
MH
Martin Hanák
Toby Metcalf
please move this discussion into Creo category.
MH
Martin Hanák
I will try and see how it work. Thank you.
