You can see in attach a solution one DAE (Simple Pendulum Motion) problem.
Without units - OK
With units - not OK
What is the problem?
Jakov Kucan wrote:
The issue has been fixed in Prime 3.0 -- coming out soon.
Thanks, Яков!
All OK in Prime 3:
I can't see a good reason for your DAE to fail with units but work without units. I've attached an x-y version that does work with units, but it is formulated in ODE-only form, not DAE form (and if I change it to DAE form it fails with the same "incompatible units" error).
Alan
AlanStevens wrote:
I can't see a good reason for your DAE to fail with units but work without units. I've attached an x-y version that does work with units, but it is formulated in ODE-only form, not DAE form.
Alan
It seems to me that Prime can solve ODEs with units, but cannot solve DAE with units.
Jakov! Is it so?
PS
Allan, I will be in London (University of Greenwich) 8/30-7/9 and will be glad to present You my Mathcad-clock - http://communities.ptc.com/thread/32536
OK?
Valery Ochkov wrote:
PS
OK?
Great! But what are the dates exactly? Is that 30th Aug to 7th Sept. or what?
I guess these are the dates as the conference on water and steam properties is 1st to 5th Sept. I have a meeting in London on 4th Sept. Hopefully we can meet then.
Alan
PS
OK?
Alan
Fine!
I have free time 4th Sept.
We can have a meeting if... I will get UK visa. It is very difficult...
Alan
Alan!
I am now in London. With Mathcad-clock
Hotel: De Vere Venues Devonport House, room 202
Address: King William Walk, Greenwich, London
We are looking into this... It should work.
Thanks, Яков!
All OK in Prime 3:
