DJM
DJM
After calculating a long series of values in MathCAD, it would be convient to summarize the results in a table as shown below:
Axial Max Shear Max
Case I
Case II
etc.
How do you generate a summary table of the calculated values? The finished product should look like a table generated in Excel.
MikeArmstrong
(To:DJM)
Have a look at the attached simple example.
Let me know if your having trouble with it.
Mike
8 REPLIES 8
MikeArmstrong
(To:DJM)
This can be done in Mathcad, but the tables don't look ascetically pleasing.
I tend to embed an Excel component into my Mathcad sheet and pass the variables to it.
Mike
Thanks for your reply. How do you display only the results of a series of calculations into the Excel spreadsheet (table?) ? I've only been using MathCAD for able a week.
Example:
Calculated Pressures
P1 = 2.5
P2 = 9.0
P3 = 7.2
Record # Pressure
P1 2.5
P2 9.0
P3 7.2
Thanks Again
DJM
MikeArmstrong
(To:DJM)
Mike
Thanks for your help. I'll work with the second example.
DJM
MikeArmstrong
(To:DJM)
If your like me and like to summarise your results in a table above the analysis. There is a scripted Excel component which will do exactly that. It collates the results and display above the analysis.
Once your happy with the embeeded Excel example and feel the need for the scripted component I'll post an example.
Mike
StuartBruff
(To:DJM)
Axial Max Shear Max
Case I
Case II
etc.
Do you mean something like the attached, Dennis?
Mike's right though, that it looks a lot better in Excel ... can't remember what Prime will allow.
Stuart
WOW! Thanks for your reply. I have only been using MathCAD for about a week and your WAY beyond me. The resulting matrix would consolidate the results in an orderly manner but I was hoping for a simplier solution.
Thanks Again,
DJM
MikeArmstrong
(To:DJM)
Stuart's examples are usually superb and always worth keeping hold of.
Have a look at the attached a very simple example which might help get you started.
Mike
