In Mathcad 4.0 it is not possible to show date in ISO 8601 format (YYYY-MM-DD), e.g. in the page header.
As this is the format we are using in our office, I'd like to add that as a choice.
And even if you choose the 'dd-mm-yyyy' format it shows as dd/mm/yyyy !
Prime still leaves too much to wish for.....
Still not fixed in Mathcad 5.0.
Case 14575068 has been opened.
If that is indicative of the number of open cases for Prime, and it would take PTC on average 1 minute to solve each case (which is very optimistic...) you might need to wait some 27 years for a solution.
That would be about the time when Prime lives up (at least partially) to good old Mathcad 15.
If Mathcad/Prime still exists then.
At least support just called me now, which is a good start.
Just got feedback from support, that they propose that I write the date as a text...
Next question was, if we can consider that case solved.
Aeh.....no, I wouldn't consider that a solution.
No, this comment came by mail. So the answer didn't take longer than 10 seconds.
Splendid - case closed.
Must be submitted in community and voted upon.
Hi Andreas,
I would suggest to submit product idea:
https://www.ptc.com/en/support/article?n=CS159429
This Case will be closed.
@AndreasZieritz wrote:
https://community.ptc.com/t5/PTC-Mathcad-Ideas/Date-in-ISO-8601-format/idi-p/573617
I would happily vote for that idea (even though I am convinced it won't matter at all) but I am not allowed to do so (even though still under active maintenance).
Same here.
Maybe it's just PTC's implementation of /dev/null.
I don't see this idea listed here: https://community.ptc.com/t5/PTC-Mathcad-Ideas/idb-p/PTCMathcadIdeas
Ah, bad luck:
Product ideas do not apply to Prime 5...
And I haven't found out how to vote on any of those things in addition...
What a mess.
Hi Andreas,
Thats great! Submit a product idea as a support solution! Thats really support made by PTC. The idea you atre supposed to submit would be that PTC fixes a program bug - incredible!
BTW, it seems that since the transition from Jive to Lithium nobody is able to vote for Mathcad ideas ;-(
Not that I would miss this "feature" as those product ideas never made sense anyway and were just a placebo from the very beginning.
I had similar experiences with PTC "support" concerning wrong results from integrals. I was contacted by phone (which was funny) and support was very friendly and polite but completely useless and helpless and seemed not to have much knowledge about what kind of a beast Mathcad is. Needless to say - the case was closed without the slightest hint of a solution in sight.
