Date in ISO 8601 format
AndreasZieritz
7-Bedrock
In Mathcad 4.0 it is not possible to show date in ISO 8601 format (YYYY-MM-DD), e.g. in the page header.
As this is the format we are using in our office, I'd like to add that as a choice.
1 ACCEPTED SOLUTION
21 REPLIES 21
And even if you choose the 'dd-mm-yyyy' format it shows as dd/mm/yyyy  !
Prime still leaves too much to wish for.....
Still not fixed in Mathcad 5.0.
I am not surprised.
Case 14575068 has been opened.
If that is indicative of the number of open cases for Prime, and it would take PTC on average 1 minute to solve each case (which is very optimistic...) you might need to wait some 27 years for a solution.
That would be about the time when Prime lives up (at least partially) to good old Mathcad 15.
If Mathcad/Prime still exists then.
At least support just called me now, which is a good start.
Just got feedback from support, that they propose that I write the date as a text...
Next question was, if we can consider that case solved.
Aeh.....no, I wouldn't consider that a solution.
I suppose that phone call took more than a minute. ...?
No, this comment came by mail. So the answer didn't take longer than 10 seconds.
Splendid - case closed.
Must be submitted in community and voted upon.
Hi Andreas,
I would suggest to submit product idea:
https://www.ptc.com/en/support/article?n=CS159429
This Case will be closed.
https://community.ptc.com/t5/PTC-Mathcad-Ideas/Date-in-ISO-8601-format/idi-p/573617
I would happily vote for that idea (even though I am convinced it won't matter at all) but I am not allowed to do so (even though still under active maintenance).
Same here.
Maybe it's just PTC's implementation of /dev/null.
You have to go to "New Ideas".
Ah, bad luck:
Product ideas do not apply to Prime 5...
And I haven't found out how to vote on any of those things in addition...
What a mess.
Hi Andreas,
Thats great! Submit a product idea as a support solution! Thats really support made by PTC. The idea you atre supposed to submit would be that PTC fixes a program bug - incredible!
BTW, it seems that since the transition from Jive to Lithium nobody is able to vote for Mathcad ideas ;-(
Not that I would miss this "feature" as those product ideas never made sense anyway and were just a placebo from the very beginning.
I had similar experiences with PTC "support" concerning wrong results from integrals. I was contacted by phone (which was funny) and support was very friendly and polite but completely useless and helpless and seemed not to have much knowledge about what kind of a beast Mathcad is. Needless to say - the case was closed without the slightest hint of a solution in sight.
You wouldn't believe it, but more than 7 years later this requested feature is actually implemented in Mathcad 10.
...not that it matters for us anymore
