Debugging PRIME Programms
Newbie
in the old Mathcad you could step to the last error in programms, now I have no clue what the meaning of the messages are...
thanks
Tags (3)
14 REPLIES 14
Re: Debugging PRIME Programms
Maybe the absence of any debugging tools was made on purpose and users of Prime are not supposed to do any programming at all. As PTC stated it here in http://blogs.ptc.com/2012/02/29/mathcad-prime-2-0-is-here/:
"Today, we are proud to release a powerful productivity and analysis tool that allows engineers to stay focused on engineering, and not programming and debugging."
'Nough said.
thanks
Valery, you are referring to statements, not a program.
sorry now it works...
funningly enough the errors disappear with time - walking backwards through the errors - and reappear after starting the process again..
PRIME is a wonder!
Efried wrote:
PRIME is a wonder!
... but has not trace and pause functions and the trace window
Regular Mathcad has those debbugind tools:
http://twt.mpei.ac.ru/ochkov/Mathcad_12/6_24b_Trace_in_MC13.gif :
Trace operator in Mathcad Prime (as in Mathcad 12, 11, 2001,,,
Dear Valery, I like your approach. But if you head for a walk through in a programm with errors this method is not of big help unless you insert an "onerror" statement which returns the current state. Again such functions are lacking in Prime.
I personally do not understand why it is so complicated to give programmes the same set of functions like in Mathcad. For the moment I'm stuck because it is not possible what went wrong converting the sheet from Mathcad to prime.
Another problem with storing the tracing results is that this may create memory problems.
One old idea for programm debugging - useing not the add line operator but a matrix:
But again this won't help for stepping through a program which has errors, as was demanded by EFried, or does it??
