Display graphics
ptc-4346041
Display graphics
Can you to help me to display the graphics Mod1(f) = f(f) ? Please.
Thank you in advance.
Olivier
You call function I1 in functions Mod1 and Ph1. However, you haven't defined function I1 anywhere, so Mathcad is using the in-built Bessel function called I1. Should you be calling function I1a instead?
You also have problems further down in the file caused by the fact that your H functions (H1, H2 etc) produce complex values.
Alan
Try changing the range of values ​​for the variable "f".
MikeArmstrong
(To:VladimirN)
Reducing the number of elements might help.
Mike
Alan
thank you for your help, these equations are very important and I would like to find a résulat for each graph.
I want to display TF191(f, tpas) + TF291(f,tpas) or TF4569 + TF4570. The result should be the same but I do not understand the difference between Mod1(f)/m1 and Mod1561(f456). One uses a frequency sweep and the other a vector.
MikeArmstrong
(To:ptc-4346041)
Unfortunately I cannot seem to find these variables within your worksheet. Can you identify were they are as it's time consuming searching through worksheets laid out across multiple pages.
Mike
