When I create an Analysis from the Analysis tab in Creo Parametric (no "Behavioral Modeler"), the only "type" option available is Prime Analysis. From the Prime Analysis dialogue, I can initiate or load a MathCAD Express Prime 3.0 file. I gather from my reading that in order to pass data between MathCAD and Creo, I need to assign a region tag to the math region in MathCAD. I have read that this is done by right-clicking on the region to bring up the Properties dialogue where the tag can be assigned. Unfortunately, when I right click on a math region in MathCAD Express, there is either no response or just a simple cut/copy/delete menu with no properties item. I can find no alternative for properties or region tags in MathCAD Express Prime. Am I correct in concluding that I'm up the creek without a paddle, or have I overlooked something?
Hi Phillip,
Mathcad Prime 3.0 Express does not support region tags. Those tags you are talking about are used in versions of Mathcad 14/15. In Mathcad Prime Express 3.0 version tags are not used to transmit/receive data with Creo, you must use the tab "Input/Output" and then select "Set input/Set output". Of course, Creo 3 support Mathcad and Mathcad Prime analysis.
Phillip,
ask PTC Support.
Martin Hanak
Hi Phillip,
I also found your link to an in depth exploration of this topic here: http://communities.ptc.com/videos/4501
This webcast touches on non-scalar values as well.
Some video:
1. "Creo Parametric and Mathcad Prime 1.0 Integration (Transmission Shaft)": http://communities.ptc.com/videos/4502
2. "Creo Parametric 2.0 integration with Mathcad Prime 3.0": http://communities.ptc.com/videos/4501
3. "Link Mathcad Prime 3.1 input/output regions to Creo Parametric 3.0 parameters": All PTC Mathcad Prime 3.1 Tutorials
