The sheet carefully avoids program structures, and was probably developed for an early version of MC, perhaps 5 or 6, before programming structures were standard (they were first introduced in MC6, but only in the pro version). I doubt that the e-book has been reviewed or revised since then.
If this is an e-book that PTC has for sale and included as a bennie in the MC14 upgrade, then you could, if you have a maintenance contract, file a bug report against that e-book. If this is one of the many e-books from the library, freely available for download, and PTC merely pacakaged a copy with the MC14 disk then nobody has any responsibility for the e-book -- library files are strictly on an as-is basis.
Interesting difference in viewpoints. You looked at the sheet and was impressed by how compact it was. I looked at it and thought it was remarkably convoluted. I find the repeated use of the sin/cos of a modified arg (encapsulated in an if) to be quite strange, as some simple complex arithmetic would do the job. I also suspect that it is unduly complicated by being done by components (magnitude and phase) rather than just using complex values, but don't know enough about the application to know how to do that (no idea what the different types of busses mean).
__________________
� � � � Tom Gutman
