Eccentrically loaded weld groups
The attached application calculates the ultimate load capacity of weld groups eccentrically loaded in shear, considering the additional strength available when applied loads are at an angle to the weld elements. It should be of interest to anyone who must design or investigate the load capacity of welded connections.
This is a Mathcad 8.0 Professional application.
Tom Magner
The application should be set to manual calculation if you want to avoid calculating lengthy problems in the Example section.
In the comment under the input table of Example 4 the rows should read 0 to 23, and the columns should read 0 to 15.
Tom Magner
