Editting Autocad Object in Mathcad 15
mathcad_user
I am using Mathcad 15. Usually I will copy and paste drawing from autocad to Mathcad worksheet.
Then, when I right click the Autocad drawing in my mathcad worksheet, it only have option edit DWGTrueView object but cannot edit it with DWGTrueView.
Can someone please show how to edit the Autocad drawing embedded in Mathcad using autocad?
You can review the attachment.
Thank you
5 REPLIES 5
Sometimes it requires a double-click to open an object for editing.
If double click it still will open DWGTrueView
what happens if you double-click Autocad drawing file in Windows Explorer ?
Martin Hanák
it will open up Autocad.
following information is my guess, only ...
1.] in Windows environment AutoCAD is assigned as application used to Open dwg files
2.] in Windows environment DWGTrueView is assigned as application used to Preview dwg files
Maybe your IT can verify the above idea.
Martin Hanák
